Guyz,
I am really in need to appropriate advice. I am running low on budget, but am getting bluestone pavers 60x40x20, on clearance and it's the amount I am needing . I got gravel all compacted and levelled.
So far so good .
Issue:
I am told, if I am putting sand base, it will be cheaper to install but I will be breaking stones.
To properly do 20mm stone, I need to get concreting done and lay it over it, that way it will remain forever.
I don't understand why I need to do concreting to get bluestone paver, that's double the cost, and concreting a 40 sqm area is costing me over 3500 as they need to remove the gravel in order to get it leveled and concrete poured accordingly.
I have asked an installer if he can do with sand and cement base, so it's more stable and he is like he needs a thick layer, since the stone is 20mm only. so he needs to remove at least 30mm layer of gravel. making it another super high cost for installation due to the fact currently, the labor is skyrocketed.
I need advice as to what is the best and more stable way to do it . I spend money on gravel so I can lay them with sand base as DIY, but everyone has confused the hell out of me and wrecked the costs. FYI, I am building a pergola, and this pavement area is the flooring for the pergola. so it's outdoor, but shaded and mostly covered.
please provide suggestions,as all the tons of videos I have seen it's standard sand base. The installers say , these are videos only and doesn't show what happened after few months
