Hi everybody
/m looking for 50 mm polystyrene foam sandwich panel 2.00 M x 1.00 M plus ok. I need about 4 or 5 sheets.
The skin needs to be smooth, paintable or decorative on one side or both.
Plastic like thin laminex on one side or both would be great. Price is a concern.
Light weight is important as well as good thermal insulating properties.
It should be easy to cut and shape
Also an edging system that allows windows or doorway surrounds to be easily incorporated using flexible plastic or rubber material.
Fire retardant would be a bonus.
I had thought of buying the core foam and adding the skin using thin sheets of laminex or other hard sheet but that would be lot of work and expense, messy spray adhesive. If I could find a suitable ready made sandwich I'd be very happy.
Thanks for your ideas and or suggestions
John
