Hello @DP
Welcome to the Bunnings Workshop community. It's wonderful to have you join us, and thank you for sharing your question about painting your tiled shower base.
The product that works on wall tiles is called Rust-Oleum Tub And Tile Refinishing Kit. However, It is not recommended to be used in areas exposed to extreme heat such as stovetops, or constant high humidity environments such as shower stalls. Don't use in continuous water immersion such as swimming pools, hot tubs, ponds, or saunas.
The options available to you are to clean the floor tiles with Selleys 750g White For Life Tile And Grout Cleaner and re-grout the shower base. The other option is to tile over the existing tile base. The reason I don't recommend removing the shower floor tiles. It will damage the waterproofing seal in your shower. Once it is damaged, the entire shower area must be re-done. This means your wall tiles will need to be removed as well.
I suggest having a look at this featured project - Painted shower tiles by @Chris _T. This will give you a good idea of what it can look like once the area is painted.
Let me tag our experienced members @stelz, @court_rowe and @Chris_T for their recommendations.
Hi Eric
Thank you so much for your help. I will look more into the featured post and your ideas.
Dong
