How do you join the acrylic shower sheets in a straight line? They only come with a corner joiner?
Hello @MissFi
Welcome to the Bunnings Workshop community. It's fabulous to have you join us, and thank you for sharing your question about the Estilo acrylic liner.
The closest joiner I can recommend is the Wall Art Joiners 2400mm Snow White Sheet/Panel Joiner. Unfortunately, there will be a 1mm gap that you'll need to fill with silicone. This panel joiner is meant to take 3mm panels and the Estilo acrylic panel is only 2mm thick. I suggest filling the panel joiner with silicone first before you slide the Estilo panel into it to guarantee a positive seal. All the other available joiners are just too big.
As an alternative, I recommend having a look at Wall Art wet area panels. They are ideal for the lining of walls in wet areas such as bathrooms, showers and laundries, these wall panels are available in a range of stylish colours to suit your decor.
