We are getting a couple of large batteries for our solar panels and, as they only have space to go up against the NE side of the house (facing 50 degrees so getting morning - early afternoon sun), I need to make a shade structure for them. I'm planning to weld a metal frame and line the front and top with colorbond sheets left over from a recent re-roofing exercise - and have a few questions about this. 1) Will metal hex head roofing screws self-drill into the material I'm planning to use for the frame (gal1.6mm section square/rectangular tube) or will I need to pre-drill holes? 2) Given I'm only planning to keep sunlight out, and there are lots of air spaces (the side walls and the part of the roof immediately above the batteries will be open to enable passive cooling), is there any advantage in using some sort of sarking under the colorbond walls/roof sheets? If there is what type is recommended? 3) Any other hints/ things I should be considering?
I can't post pics at this stage as I'm just planning prior to battery delivery/installation, and keen to get my design sorted so I'm ready to build when it all happens. However, to give an idea of the scale, each battery is 790w x 1179h x 250d and I need to have 900 clearance above, 200 below, and 600 on each side with the right hand clearance needing to be screened due to where the sun will track.
