Am laying a laminate floor throughout most of house with carpet in bedrooms and tiles in bathrooms & laundry.
I am looking at the installation of the transition strip between the laminate floor and the carpet area (usually under a door).
looking at the product (or similar) QEP 25mm Transiti0n Cover Strip, are there 2 pieces to this solution or how do they get secured?
Is there a base component that is secured to the concrete between the carpeted & laminated areas that the trim cover is then clipped into?
They are of similar height so do not really need ramping solution, but may need to transition to tiled areas as these are a bit higher. Is the solution the same for these?
Regards
Dion
