Hello everyone. Need some expert advice. My cold tap (bottom) is leaking a lot (from picture) when it is turned on . I thought it was the problem with the hose and I change it to a new hose. However, it turns out it may be the tap.
The hot tap (top) sometimes leak a bit when it’s turned on but it’s not as bad as the cold tap.
What do I need & how do I to repair this?
Thank you so much.
Cheerio,
DChew
