Hi there @innessa thank you for sharing your concern about your Lilly Pilly. I zoomed into your photos and it looks like they have Psyllids which is an insect that attacks the new foliage causing the leaves to look like they have pimples on them. This is a very common problem with Lilly Pilly and easily fixed. Cut and remove affected leaves and throw into the bin. Don’t leave on the ground or put in the compost heap. Then give them a good spray all over with Eco Neem Oil or a Horticultural Soap Spray like Natursoap.
Make sure you wear protective clothing, mask and gloves when handling an insecticide spray. Don’t spray in the heat of the day. Later in the evening or early morning. Follow the instructions on the bottle.
Good luck with them. 😄
Hello @innessa
Welcome to the Bunnings Workshop community. It's great to have you join us, and thank you for sharing your question about your lilly pillies.
It's great that you've received excellent advice from @mich1972. I totally agree with the recommendation of using neem oil to control the insects. Please make sure to wear personal protection such as a long sleeve shirt, gloves, goggles and a dust mask when using the neem oil.
Can i add , i have had similar issues with ours, make sure you are a bit rough on the leaves and branches when you spray them get right into everything , you will see the little critters fall off and they cant get back up, even give them a bit of a brush with a soft rake ,this also knocks the Psyllids off
Hello @wooshka
Thanks for that extra recommendation, let me tag @innessa to make sure they see the suggestions that you've made. You're absolutely right the spray must be applied both above and below the leaves. Physical removal is sometimes necessary especially if the Psyllids have dug into the plant.
Again, thank you for sharing that extra information.
Hello @innessa,
Jumping into the discussion to suggest having a look at the Bunnings guide on How to grow and care for a lilly pilly in case you haven't already. It contains information that you may find useful, including advice on dealing with Psyllids.
Hope this helps.
Akanksha
Here is a photo to show everyone who might have Lilly Pilly growing in their garden and are having the same problem. This is mine. I cut and remove, put it in the bin when it appears. The classic signs are the pimples.
@Akanksha Thank You for sharing the growing and care guide for Lilly Pilly, it’s brilliant and very informative for everyone 😀
Why no leaves growing on the bottom? And plants are not growing straight?
Hi @innessa
Perhaps the plant is still young. How long have you had the Lilly Pilly in the ground? When was the last time you fertilized the soil? Lilly Pillies grow more leaves when they are aggressively pruned, however, it must be done at the right time and at the right stage.
Let me call on our experienced members @Noelle and @Adam_W for their recommendations.
Why is the lillypilly growing in a pot submerged in the garden, and not in the soil itself? Confining the roots in that way will restrict the plant's ability to source food and moisture, the roots will not be able to spread out to anchor the tree firmly in the soil and it will most likely not thrive. Plant it into the garden now, before the weather starts to cool so it will establish a decent root system while the soil is warm.
Trees grow straight by giving them sturdy support, like a 1.8m tall garden stake, and tying the tree to it. Not so tight as to cut into the bark but firmly enough to train the tree to grow upright. The stake needs to be driven well down into the ground - something that isn't possible while the tree is in a pot.
Feed it with a controlled release fertiliser suitable for native plants twice a year - at the start of spring and again at the start of autumn as per the label instructions. Don't start pruning to form a hedge until all the trees are at least 1.5 - 2m tall.
Agreed with @Noelle I never saw this photo. No good sinking pots into the ground. The plant is probably root bound and the roots will need to be teased out. Make sure you add a soil improver into the hole. As Noelle gas has suggested, take out of the pot and plant it straight into the ground.
They are not in a pot. I put plant barrier around so nothing comes near it. I put fertiliser on top.
Apologies @innessa It looked like a pot.
Sorry @innessa - definitely looks like a pot. Fertiliser, moisture and staking are essential. As lillypillies grow, the lower leaves and small side twigs will die off - that is natural as all the growth and energy occurs at the top of the plant and the tips of larger side branches. The trunks will not remain leafy right down to the ground.
Thank you for replying. I am so confused with the plants. I got 50 planted by a landscaper and half not looking healthy. They look like they are on a slant and no new leaves.
Hi @innessa very frustrating when this sort of thing happens especially when plant shave been professionally installed.
I've a little video on fruit tree planting which has some information you may find useful. It's about staking and is from around 2:20
Trees & shrubs should never be left attached to their nursery stakes once planted. Those stakes are intended purely to keep plants safe and tidy during transport & nursery and the little bands on then can restrict sap movement.Those stakes may well explain the funny angle they are all on.The patchy growth may be due to lack of water but, equally, could be because they are not establishing a quality root structure due to those stakes.Personally... I'd be digging one up to look at how the roots have developed and see if they are any problems below ground, such as curl grubs.Will add too... I'm not a real fan of the type of weed mat that appears to have been used.
Hi I too have problems with my Lilly Pilly's planted in a rural setting ..at first my tube stocks were eaten by rabbits!!!! Then magically the tough little ones grew back now that spring has hit they are not growing !! They have leaves which appear to be half eaten or little nibbles out of them ... not rabbits as they ate the entire plant before we placed plastic protection cages around them.. Also then went to Bunnings and purchased 4 larger plants thinking the rabbits wont eat those and they didnt!! yay ... however now they too arent growing and losing their leaves or half eaten...
I cant see any lumps, no holes in branches, have looked under mulch to see grubs.. non present... the soil is moist they are in shade from afternoon sun... ... we have almost 20 plants in all that we thought would grow fast to privatise our rural boundary... very sad.. please help ...
Should I use the neem oil even if there doesn't appear to be grubs?
Ill try and upload some pics
Hello @LillyPilWrKshop
Looking at the three photos you posted it looks like the first one needs some liquid fertilizer, the second one seems like an insect attack and third one is definitely animal damage. In order to discourage further attacks I suggest spraying the plants with soapy water, the soap residue should give the leaves a bitter taste. You can also spray the surrounding area with vinegar.
In regards to the conditions that you've mentioned, the only other thought that comes to mind regarding your plant's growth is perhaps they need more fertilizer. I propose having a look at PowerFeed 600mL Fertiliser Liquid Concentrate
Let me call on our experienced members @Noelle, @mich1972 and @Adam_W for their recommendations.
Hi @innessa Looks like your Lilly pilly is screaming for a good feed. Also the soil looks very dry . As @EricL recommended, liquid feed should help it and I also suggest adding some soil improvements around it to nourish the soil 😊
thanks for the advice.. ive sprayed vinegar around to deter animals none have been intruding since then 🙂 and had been using seasol liquid fertiliser.. but will try what youve suggested... the ground looks dry on top but is moist under.. we also have decided to place a pvc pipe into ground to water down to roots ..
as for soapy water ... do you suggest ? dishwashing soap ?
thanks Mich can you recommend "soill improver"?
Hi @LillyPilWrKshop
I suggest having a look at the Yates 17.5kg Dynamic Lifter Organic Plant Fertiliser and Soil Improver. This is used to gently feed all types of garden and potted plants, including Australian native plants. It releases nutrients slowly, improving the structure and moisture retention of the soil as well as encouraging earthworms and beneficial soil micro-organisms.
Hi @innessa Just a good organic soil improvement. Here in Perth , I love to use Baileys Soil Improver. Otherwise a good Compost. I also like @EricL @suggestion of the Dynamic Lifter 😊
