Welcome to the Bunnings Workshop community @vivad. It's fantastic to have you join us, and many thanks for your question about painting Dado walls.
I'd suggest you start by giving the timber a light sand with 240-grit sandpaper to remove any glossy surface. You can then fill and repair any dents or damage that aren't aesthetically pleasing. This can be done with a timber putty filler and a scraper. Once you've filled the damaged areas, you can sand them back smoothly and flush with the surrounding surface. Give the wall a good clean to remove dust and then use a specialised primer like Dulux Max Adhesion to prepare the surface for painting. This product is designed for difficult-to-paint services like previously varnished timber. When the primer is dry, you'll be able to paint the wall with a water-based enamel paint which will give you a fantastic finish. I suggest using a fine nap roller to achieve the best result.
You'll likely find it easiest to use a fine brush to paint the v-grooves in the panelling first before rolling the primer and paint. This is because the roller won't be able to get into the grooves.
