How to install bathroom cabinet to brick wall
Hi @Oo,
No washers are required with those masonry anchors.
Welcome to the Bunnings Workshop community @Oo. It's great to have you join us, and many thanks for your question about installing cabinets on a brick wall.
Typically you would use at least four Ramset 8 x 60mm Countersunk DynaBolt Plus Masonry Anchors per cabinet. You'll need to pre-drill the bricks and the cabinet with a 10mm hole to accept the Dynabolts. I suggest drilling the cabinet first and positioning it on the wall. You can then mark through the cabinet holes and onto the wall. Remove the cabinet and then drill those marked locations on the wall. You then be able to fix your cabinet to the wall.
Thanks for your help
Please advise if I need washers with the bolts
