Hi all,
I would like to build an outdoor wall (~2m high) close to the meter box side of the house, which will be used to mount two solar inverters and fix a home battery (1.2m high) so it doesn't fall by accident. This wall will also need to have a top cover to protect the battery for the elements. The outside of the wall will also be used as a screening for all other electrical systems.
I wouldn't like to attach it to the house as the wall is Hebel panels, so I'm thinking of some kind of freestanding mini-pergola with either 2 or 4 posts.
I will put up timber screening panels on the outer side and some metal bars on the inside (for the inverters).
I'm interested to know what kind of posts I should use, so they are strong enough to hold 2 inverters (23kg each) AND wouldn't move (2m high).
Concrete will be extended, should I use in ground posts and do them before pouring concrete, or can I do it with brackets mounted on concrete?
The length is around 3.5m, the cover/overhang will be around between 0.6-1m
Should I use 2 posts or do I need 4 posts for it to be more stable?
(Actually there will be 3 posts - an extra post in the middle, as it spans over 3.5m)
This is what the area looks like with some basic drawing of what's in my head:
And these are some ideas I found:
Structure with 2 posts
Ideas with 4 posts:
I would appreciate any help / suggestions.
Thank you,
Peter
