I'm working on a design for a small, low level deck for the laundry entrance on the side of my brick veneer house. I think I have the design of the frame mostly down pat, but had a few questions on some of the specifics.
Design:
- The size of the deck is 2400x1155. I wanted ~1200 and 1155 is the closest size with 140x19 deck panels and 5mm spacing
- 140x45 ledger board + bearer and outer joists (are they joists or a bearers?)
- 90x45x1050 joists approx 395mm center to center
- Doubled joists for picture framing
- 140x19 merbau decking panels
Questions:
- Do the outer joists/bearers need to be 140x45 or can I get away with 90x45s?
- Are dynabolts suitable to secure the ledger board to the brick veneer? If so, how many of what size? If not, how to I support the deck on that side?
- What should I use for posts on the outer edge? Currently planning to use 3x center fix post stirrups so the outer deck boards can neatly cover the bearers, but is this the best idea? It's currently just grass underneath and I'm happy to set some concrete.
- I am planning to use joist hangers, but how do I hang the doubled joists? There isn't a 90x90 joist hanger for sale. I could take a 90x200 hanger and cut it down, but that seems odd to need to do that. Am I missing something?
- Current the bottom edge of the deck will be about 150mm clear of the ground. Should I be designing the deck to come down another panel to be more flush with the ground? If so, how do I do that?
- Currently the area is grass and slopes away from the house slightly. I've seen a few posts mention drainage, but don't have a good understanding of that. Where can I get info on what is required?
