I want to paint my bathroom and laundry tiles but the tiles have some chips and cracks. What should I use to repair the tiles prior to painting?
Welcome to the Bunnings Workshop community, @kimmyg. We're thrilled to have you join us and look forward to seeing and assisting you with your home improvement and garden projects.
Is it possible to post photos of your bathroom and laundry tiles? This will help our resident Bunnings D.I.Y. expert @MitchellMc and other members get a better idea of the damage on the tiles, enabling them to provide more tailored advice suited for your needs.
Let me know if you need a hand posting photos.
Akanksha
Hi @kimmyg
You might be better of tiling over the top of you old tiles for the best results as there is no guarantee a fixed crack wont reopen and it is hard to reshape damaged tile edges before painting with a specialized tile paint.
Like
Rust-Oleum Tile Transformations Coating System
I/N: 1370099
$179
Hi @kimmyg,
@Jewelleryrescue is correct that if the existing tiles are not in great shape it might be worth considering a more permanent option. However, if there are just a few odd cracks and chips and if you're looking for a budget refresh, then I see no reason why you couldn't use a filler such as PC-11 56g White Epoxy Paste. Make sure to only apply enough to fill the chip or crack, as that will make sanding it back flush with the tile surface easier. A scraper will help you apply and push the filler into the areas.
