ozito line trimmer just stops in between. I sometimes have to twist the wire to make it working but it again goes out every now and then. The wire lead works well with mower.
Hello @Cs12 from your description you have a mains powered line trimmer?
If you have to manipulate the device power cord to get it to operate it would indicate a fractured wire or internal issue, do you still have the receipt or a bank statement with the purchase details? How old is the device, is it still under warranty?
https://www.ozito.com.au/services/warranty/
Hi @Cs12
If your lawnmower working ok on the same lead.
You might just have to make sure the plug joined all the way in. Pushed in and connected properly for starts
Other wise there might be an electrical faulty wire in the line trimmer. Ii will need replacing for best results.
Welcome to the Bunnings Workshop community @Cs12. It's wonderful to have you join us, and many thanks for your question about an Ozito line trimmer.To clarify, are you saying that in order to get the line trimmer to work, you need to twist the short connecting cable on the handle of the trimmer? If so, discontinue use and take it to your nearest store. If the unit is under warranty, it will be swapped over for you. Please take along your proof of purchase.Mitchell
