Installed yesterday but they seem to lean down and things keep sliding off. Did I do something wrong. I really don't want to put a bracket underneath that defeats the purpose of buying these
Hi @KMS
Is that the flexi storage shelving?
In any case take the shelve off again and try make sure those scews especialy on the top egde are in nice and snug but not pulled though the wall.
Behind your shelving will be vertical studs if you could find one and put a screw through the wall bracket into a solid stud at the top edge of the bracket then your shelf could hold a decent weight around 10 kg or a little more with out drooping.
There is an arrow on the wall bracket pointing up is your wall bracket on the right way up/ as the construction may pre counter some estimated droop
Message back if you need more help
Hello @KMS
Welcome to the Bunnings Workshop community. It's splendid to have you join us, and thanks for sharing your question about your floating shelves.
It's great that you've received excellent advice from @Jewelleryrescue. Sometimes the screw and anchoring system you use is not sufficient to hold the weight of the shelves. In an ideal situation it would be great if the shelving frame could be anchored to one of the studs in the wall.
Can you please tell me what wall anchor you used on your shelving frame? I often suggest using the Ramset Super Wallmate Toggle Anchor - 10 Pack when anchoring floating shelves. But even then, sometimes the plasterboard itself bends due to the weight applied to the surface.
I also suggest checking out the orientation of the shelf as it might have a preferred position when sliding it into the wall frame.
How did you go with the advice shared @KMS? Please let us know if you need additional assistance. We're here to help.
