Looking for some advice and information on getting a concrete slab down for a 3x3 or maybe even a 4x4 shed.
After using a couple calculators found on the web they say i will need approx 100-150 x 20kg bags of concrete, is this correct? or does it seem excessive for a 3x3-4x4 100mm slab, this means it will be $1000-$1400 worth of just concrete bags, at this point i feel like maybe just buying some already made smaller concrete slabs, or even paving would be much much cheaper.....
does the slab really need to be 100mm thick? could i not get away with 50mm ? it will only be used as a small workshop for small welding projects and wont even have anything heavy in it.
My other issue is i will be doing this job on my own, this means the typical way of pouring the concrete might be an issue, i cant see my self mixing and pouring 100-150 bags worth of concrete and also prepping and making it flat before it dries in the pad area, would it be ok to dry pour it? even though ive watched about 30 youtube videos of successful dry pours of pads much bigger than what i need, for some reason i am still very sceptical about the process...
the other option would be splitting the pad into 4 parts, this means i could try to pour the slab the usual way as each part would be smaller and split into 4 jobs, using metal mesh on to "connect" the 4 pads into one.
keep in mind my yard and house is not set up in a way where a truck can come and pour the concrete, paying someone to deliver and pour it is not really an option as either way they will need to cart everything over from the street into the backyard and would cost a LOT in labour just for this part. i dont want a slab for a small shed to turn into a $5,000 project.
Any advice appreciated.
