Hi, I previously had to retile a small area of my laundry that used to have the hot water heater.
Due to passage of time from when it was originally tiled, I couldn't find the exact same tile again. I could find one that was pretty much similar, but it was thinner than the original one.
I retiled with it- but there is a small little dip when you walk onto it.
I may need to retile more of the laundry if I move some more around- how can I use the thinner tile but make it the same height as the existing thicker tiles? or will it just be easier to remove everything and start again with the thinner tile?
