I've sliced the surrounding silicon seal, and started chipping away at the surrounding tiles. The tub is starting to loosen up, but the drain end is still rigid, obviously because the drain is still connected.
Unfortunately the drain is plastic, and the cross bars broke away the instant I touched them and so usual methods for removing it are out of the question.
I am looking for advise on:
- How to remove the drain.
- How to remove the bath. It's fibreglass, should I just slice it up with this: https://www.bunnings.com.au/ozito-pxc-18v-cordless-reciprocating-saw-pxrss-400-skin-only_p6290473
- How to remove the small 'wall' (highlighted in the pic). I'm guessing it's brick under the tiles.
Just an FYI, this will be a permanent removal of the bathtub so I don't care if it gets damaged (the plan is to retile and grout etc once the bath is gone).
