Hello @Nesian
Thanks for sharing your question about moving your taps. Just a friendly reminder that any plumbing work must be done by a licensed plumber.
It's possible that the plumber will either use a Kinetic 15mm Wall Tap Spindle Extender - 2 Pack or a Brasshards 15mm Brass Male / Female Threaded Adaptor to extend the mounting point of the taps. There is also the option of welding more copper pipe to your existing plumbing. But it all depends on what the plumber will find when the taps are taken out.
Thank you for that.
I wasn't too sure if that was the case or not. I had seen a couple of videos using the tap extender, so I was hoping it was something a home owner can do. It seems crazy that you have to call out a plumber to do such a easy procedure.
