Hi
I'm looking at installing a side fence using EkoDeck Castellated Panels. 3600 high x 14.4 m long. Since fence will start about 400mm off the ground, the actual panel height is 3200. I'm looking at installing the panels horizontally on in-ground steel posts, not vertically.
I believe the posts should allow 1/3 extra length to be cemented in-ground, so am looking at posts about 4.8m high (3.6m+1.2m in ground), and that 50x50 square posts are the go.
Assuming the above is correct, can someone advise what gauge/thickness the posts should be?
Also EkoDeck say the spacing between posts should be 600 Max, which seems overkill, since the normal EkoDeck screening boards specify 900mm spacing, which seems more reasonable. Can anyoine comment on the spacing as well?
Thank you in advance for any insight!
