The motor came on and then stopped
It works if I take the end (jet) attachment off. I have looked for any blockages doesnt appear to be any cant blow through it though
Help
Thanks Tyrone
Hi @tyroneandrews,
Is it possible to get some photos of the jet attachment? It sounds like the motor is shutting off as a preventative measure due to a pressure build up caused by the blockage.
Have you tried using your hose to run water through the jet attachment? Did any water get through?
Without seeing it, it would be difficult to diagnose the issue, but there may be washers that can be replaced, or you might be able to clear the blockage with a pipe cleaner such as this Ramset 20mm x 300mm Hole Cleaning Brush.
If you can't locate the blockage, you could always order a replacement attachment. If you would like to order a replacement attachment, I'd suggest contacting our Spare Parts Team for assistance with ordering.
Thank you so much Jacob for responding and with such great advice.
Apparently it was the ball bearing in that jet piece and had poked it and it became free and now works better than ever.
Many Many Thanks & Best Wishes
Tyrone
That's brilliant to hear @tyroneandrews.
I'm glad to hear it worked out well and everything is now working.
If you ever have any other questions, please think of us and don't hesitate to reach out.
