My cousin is wanting to erect a 4.1 X 5.0m free standing pergola. It will be single span with only four posts in each corner.
What kind of 100x100 posts would you advise to be exposed to the weather elements?
How do I read the span tables for this to determine the size of beams. Im assuming 240x45 or there abouts would be rough size.
Can i simply notch out the tops of the 100x100 for the bearers and use bolts M10s for these and also use stirrups on the bottoms concreted into ground?
If the length of the pergola is 5m what space could i get away with for additional joists etc and can these simply be joist holders installed.
If there is overhang needed for a visual impact are you better to install the joists above the bearer and notch out or have separate pieces each side with joist holders?
And if installing a sheeted roof does it need to have 15 degrees minimum pitch for water runoff and there fore gutters installed?
