I have an area where I’d like to concrete and need input/advice on how to manage water drainage effectively. Additionally, I’m seeking advice on sequencing the work—fencing, plumbing, concreting, and patio installation.
Photo 1: The plan is to replace the timber fence with a lapped privacy fence and concrete the area. There’s also the potential to add a shed on top in the future, so I’d like to keep that as an option. I need a drainage solution and advice on how far the concrete should extend towards the fence. Please note that my neighbour’s land is about 200mm higher than mine, and bricks serve as a retaining wall. Since I recently purchased my home, I’m keen to ensure my neighbour’s land doesn’t flood, as the soil is against my brick wall. The drainage solution should prevent water from being trapped anywhere.
Photo 2: A four-post patio with a roof is planned, as indicated by the white-marked area on the land (note: the black striped area represents the concrete without the patio).
Challenges/Considerations:
- The elevation of my neighbour’s land is around 200mm higher than mine.
- My fencing contractor suggested placing a sleeper at the bottom of the fence to act as a retaining wall. However, I’m concerned this might cause water to accumulate against the front of my house (as the 200mm raised land runs along the entire house wall). It’s in my best interest to divert as much water away as possible.
- I currently experience pooling in various areas of my lawn, particularly in the section shown in Photo 1, during heavy rainfall.
- My land is almost completely flat, with minimal slope. A plumber suggested a subsoil drainage system with a sunken pit and pump for $14k.
Questions:
My main priorities are to replace the fence, install the patio, and address property drainage. However, I’d like to establish a comprehensive drainage plan now to avoid any issues or rework later on. Key questions include:
- Should the fence have a sleeper at the bottom, or could this interfere with water flow from my neighbour’s property, potentially affecting my house walls?
- Would a subsoil drainage system work in the area where I plan to concrete and may eventually add a shed (see Photo 1), considering it would be beneath the concrete? If not, should I install a drain channel, or is there a better solution?
- Can I handle the lawn drainage myself? The $14k quote seems quite steep!
P.S. The stormwater drainage from the roof (existing and patio) will be addressed separately. This post specifically concerns drainage of surface water not captured by the roof.
Thanks in advance!
Regards,
Sandra
