Hello experts,
I have a rainwater tank at my property which has a small brass tap outlet at the moment. This works fine for filling a watering can and such applications, but is not enough pressure to use a soaker hose or hose gun effectively (or anything more complex such as irrigation).
What sort of system is required to pressurise the water coming from the rainwater tank? Would I need to replace the brass tap output with some sort of poly piping system, or could such a system attach to the tap? The tank is quite full.
Thank you.
