How much concentrated Seasol is required in a 2litre spray-on bottle for regular application to plants and lawn?
Hi @Hilrick,
Information on the mixing ratios is available on the packaging.
Noting that 100ml is mixed with 9L for application on established lawns, this means you will need roughly 23mL with 2 litres of water.With plants, it depends on the plant you are using it on, but around 5mL should be fine.
