Hi there,
I need help in filling/covering a hole due to removal of non-functional lock.
I didn't knew that the door is hollow from inside.
Will appreciate the help to fix the hole. Please let me know what to buy from Bunnings.
Thankyou,
Most internal doors are hollow. How about a dummy handle?
There is already a handle above it.
Hi @berserk,
Thank you for your question.
I'd suggest checking out How to repair a hole in an internal door for some guidance on how to patch the hole.
You can use the same Builders Bog to fill the recess for the latch.
