I'm wanting to build some tables for games events, and being a not-handy person I could use some advice on material to use. This also has to be done on a fairly tight budget.
The table surfaces need to be 1.8m x 1.2m, and looking at making 10 of these.
Due to budget constraints, I plan to first acquire the table surface (and place on existing trestle tables at the venue), and later add foldable/removable legs and any needed support.
My main question at this point is what to use for the main table surface? First thought was plywood/mdf (because cheap), but I'm unsure what amount of support braces this will require to avoid sagging or such when adding legs and if it'd still be suitable. And if it could work, what thickness I would need.
Any advice is much appreciated!
