What’s the easiest way to remove an existing corrugated iron fence but leave the poles to grow veges along wires? There’s a new higher, modern fence built by new neighbours behind it.
Hi @mishmish
All fences held together by screws so the idea is to undo those screws and it will come apart the poles into the ground will remain behind.
But typically the screws are on both sides of the fence and there may not be room to undo the opposite side screws so I would screw your vegtable mesh/wires directly to the fence using metal hex head screws as they are easiest on metal
If you dismantle the fence you will have lots of metal to dispose of too.
Put masking tape on the fence to add screws it will stop it skating around a little more.
Or a no drill option is to put hangers on the fence and I recommend a gardening mesh hang down off the hooks. as it will allow any thing to grow there.
Hang a second mesh under the first on to reach to the ground if you need.
Jack 90cm x 5m 12 x 12mm PVC Coated Garden Mesh
I/N: 3060823
$50.99
Hi @mishmish,
If you have some photos of the fence, this will help our members offer more tailored advice. If you need a hand uploading images, please let me know, I'm happy to help if required.
As @Jewelleryrescue has mentioned, fences are usually held together with screws, so you'll more than likely have to look for the screws and then back them out before lifting the panels out of place. Wear gloves and protective clothing as corrugated iron can be sharp and cause lacerations if treated without due care.
