How do I fix the tiles on a brick wall outside the house.
Hello @mehreen
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about mounting your tiles to your brick wall.
I suggest using Selleys 350g Heavy Duty Liquid Nails in combination with ScotchBlue 24mm x 55m Original Multi-Surface Painter’s Masking Tape. The general steps will be to brush the surface of the brick wall to remove dust and debris. Apply just enough adhesive for the tile to stick on the brick surface and put masking tape on the tile to hold it onto the brick and prevent it from sagging downwards.
Once the adhesive cures you can then take the masking tape off the tiles.
