My Ikonic San Fran Passage Lever set has broken. When I turn the lever the latch only goes part of the way in. How do I remove it?
Hello @lmc17
Welcome to the Bunnings Workshop community. It's sensational to have you join us and thanks for sharing your question about your Ikonic passage set.
The cover flange of the Ikonic passage set is held in place with a rubber O ring. I suggest using a flat head screwdriver and lifting the side of it off the door. Or you can grab the flange with one hand and pull or wiggle it away from the door. Once the cover is removed you'll have access to the mounting screws.
