As the title, I can't find Crommelin brand tile adhesive and pre-mixed screed products that are compatible with Crommelin shower water proofing membrane. Any suggestion? Thanks.
Hello @reno-abcÂ
You'll notice on the description that the "Crommelin® Shower Waterproofing Membrane delivers a keyed finish, suitable for use with cement-based tile adhesives." Therefore, any tile adhesive that is cement based will work with this membrane. The same rule applies when using screed and that it must be cement based. An example of a cement-based tile adhesive is the Davco 20kg Grey Ceramacrete Tile Adhesive and for the screed there is the Easy Mix 20kg Traditional Floor Screed.
Should you decide to use another brand or product, just make sure that it is cement based, and it will be ok to use with the waterproofing membrane.
