Hi everyone,
I’m setting up my desk and could really use your advice on the best way to position the legs. Here’s what I’m working with:
Desk Top:
- Size: 200 cm long, 70 cm wide, and 2.7 cm thick.
- Material: Solid birch.
Planned Legs:
- Two square legs that span the full 70 cm width of the desk. I’ll attach a picture of the legs for reference.
Weight Distribution:
- Right side: A computer (~15 kg).
- Middle back: Three monitors on a stand (~10 kg).
- Center: Keyboard, mouse, and mouse pad.
- Front (in front of me): Joystick mounts + joysticks (~4 kg).
Do you think two legs are enough if I place them about 20-25 cm in from each end, or should I add more support?
If more support is needed, I’m considering either adding a central leg (positioned to stay out of the way) or installing a brace under the desk to help distribute the load.
Here is a diagram of the desk for even more context / informations :
Thanks so much for your help!
PS:
You can find here the link of the plate and the legs :
Plate : https://www.castorama.fr/plateau-en-bouleau-massif-80-x-200-cm-ep-27-mm/7640327560882_CAFR.prd
Legs : https://www.ecdgermany.de/fr/maison-vie/pieds-de-table-pied-de-table-set-de-2-u-design-70-x-72-cm-noir-en-acier-ml-design
Also, I found this steel plate on the web : https://www.gonser.ch/en/cross-brace-for-standing-desk-black/a-14269/
I was wondering, could that be a good solution ? Adding this plate under the desk and moving both legs to be at each side of this ? Or do you think this will not be enough ?
