I plug in pressure washing turn on motor is running but no water comes out is it my hose I have 2 hoses joined together and hose has couple little holes in it I noticed do I need a new hose than will it work cheers
Hi @Marleykj74,
It seems likely that the hose is the issue. You should pick up a new hose that is suitably long and requires no joint between the tap and your pressure washer. Please have a look through our range of Hoses, there are plenty of options.
With your new hose, you'll need to ensure there is enough water flowing through the hose for the pressure washer to kick in. This will mean turning your tap to more than half its potential pressure.
