Hello. Anyone has idea is this a fungus in lawn?Also what type of grass is this? (As per google its kikuyu)
There are dried patches. I am watering 3 times but not recovering. Also I did the soap test for armyworm and cricket (I can hear at night time) but I noticed only several **** and centipedes came out. Appreciated if someone can advise how to cure it.
Hi @kashifrana,
I do not see anything that would point to a fungus being present and causing damage to your lawn. Fungus tends to develop in lawns that are not well-draining. You will tend to see blackened or yellow splotches on the leaf blades when a fungus is present.
How often are you watering? One long soak once every 2-3 days should be enough at this time of the year. The grass looks to be Kikuyu. I'd recommend you aerate the lawn, spread a 10mm layer of top dressing over it, ensuring you don't cover the blades entirely, and then re-seed with lawn seed.
Here's a helpful guide: How to take care of your lawn.
Hi Mitchell
Thanks for your response. That is very helpful. I will follow these steps. I am watering every day evening time. Do you think, I need to spray grub killer and liquid fertilizer or seasol? Kindly if you can recommend the products
First, it's best to water in the morning, which allows the water to evaporate during the day and soak in. Watering at night is a good way to develop fungus on a lawn, as the water keeps the soil and leaves damp for several hours. Also, no need to water every day. It's much better to give the lawn a long soak every few days so the water penetrates down to the roots where it is needed.
A liquid fertiliser like PowerFeed would be a good idea. I wouldn't apply a grub spray unless there are signs of them. Grubs typically destroy circles of the lawn as they eat the roots, and I do not see those signs on your lawn.
