Hey there , I need some suggestions about how do I cap my existing versalco blocks wall. Do I have to grind the top pointy bit and then I put cap on ? Any suggestions .I attached photo of block I am using .thanks Ram
Hi @ramanpal,
Thank you for your question.
The blocks you've posted an image of are actually Versawall blocks, not Versaloc blocks.
There are capping blocks designed with these lugs in mind available in NSW, NQLD and SQLD that can be used without removing the lugs on the top row of your blocks. You can see them being set in place at 10:37 in DIY Raised Garden Bed How-to Video | Versawall® Retaining Wall Blocks by Adbri Masonry.
If you are in NSW, NQLD or SQLD then you can order them through your local Bunnings Trade or Special Orders Desk.
If you are outside of this area, then you will have to grind the lugs off before laying your caps.
