Hi there,
looking to build a besser block raised garden bed 2-3 courses high. Couple of questions.
1, will I need to use blocks on the front and back of the bed or am I able to but up to the Hebel itself?
2, can I even do this against a Hebel panel house?
3, should I waterproof the inside of the bed or is that a bad idea?
4, should this be built on a concrete slab to ensure water run off? Assuming some kind of drainage holes are needed?
any advice would be great.
I’ve built a letter box with besser blocks so I’m confident building the thing just not sure the logistics of what’s required.
thanks.
