I have a gap above my window where old mesh is currently covering and let in a lot of cold air. Trying to work out the what to cover this with. It's an old apartment unit
Hello @Len40
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your window.
I propose measuring the width of your window and see if the Bastion 1200 x 600 x 30mm XPS Multi Use Foam Board is enough to cover its gap. If the insulation panel can fit or is too big, I propose trimming it with a Craftright 18mm Snap Off Knife. You can then push the foam board all the way against the mesh to cover it and prevent cold air from flowing in.
