We had a Kaboodle kitchen installed and 2 of the cabinets were installed as pullout rather than hinged doors. Is there a fix for filling the unsightly pre-drilled hinge holes which areĀ redundant? Around 10mm deep and 35mm diameter
Hi @YB,
These Hafele 35mm Diameter White Cover Caps are a good option that will fill the central hole. You could then use these Hafele 14mm Diameter White Cover Caps to cover the smaller holes.
