My shower has been leaking from the shower head. I ruled out the shower head itself, as the leak continues even when it’s removed. I’m assuming the issue is with the tap.
I removed the tap handle and unscrewed the cartridge, expecting to replace the rubber washer. However, I found a white plastic piece inside, and it looks like there’s a black washer-type component stuck to it (red box in the image). The problem is, I can’t seem to remove this white plastic part to inspect or replace the washer.
Has anyone dealt with something like this before? What is this white plastic piece, and how can I safely remove it to fix the leak?
If you can direct me to Bunnings product link to replace this washer, that would be really helpful.
Any advice would be greatly appreciated!
