Steps
Step 1
1. Secured subfloor and concrete pavers
2. Laid damp proofing under bottom layer of bricks stuck down with mortar.
3. Laid bottom layer of besser blocks on top of mortar to get a flat and lever base
4. Used landscape liquid nails to adhere the remaining layers of besser blocks.
5. Added rebar layer on top of the top layer of besser blocks to add stability to the AAC concrete Block top.
6. Used AAC adhesive to lay the AAC blocks along the top to form a counter.
7. rendered the walls and counter top.
8. Used a 600 x 600 concrete paver to sit on top of the blocks where the BBQ will be to provide a stable flat surface to hold the heavy bbq. Stuck down with mortar.
9. Painted the top and walls.
10. Sealed the counter top.
11. Added the doors and drawer.
