folding door has detached from track at top of cabinetĀ
how to reattach? Fitting is Blum.
HiĀ @JanH,
Hopefully you will be able to simply align the hinge with the mounting plate and firmly push/shove in until it clicks.
Would be helpful if another person was supporting the door near the top to steady when you did the pushing.
If the same thing happens again further investigation is required.
BLUM Website:
https://www.blum.com/au/en/
Good luck
Hi @JanH,
Welcome to the Bunnings Workshop community and thank you for your question.
As @AlanM52 said, it looks like it may just be a simple case of pushing it back up over the track, but it is quite difficult to tell from the photo you've provided.
Blum have a number of systems, but I can't seem to find one that matches yours.
Is it possible to get some closer photos of how the attachment and rail actually fit together? Can you see any other marking besides Blum, which is the brand, that might indicate the name of the system?
Could I also get a wider shot showing more context? Mainly, what kind of door is it?
Let me know what you find.
