I have just installed a Kinetic inlet valve, and it is not letting water enter the cistern
please help?
Hello @pat22
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your inlet valve.
There are only a number of possible points where you can investigate why the inlet valve is not working.
If after doing all these trouble shooting steps and the inlet valve just won't work, I suggest bringing it back along with your docket and getting a Fluidmaster Bottom Entry Toilet Inlet Valve instead.
Mounting a Kinetic toilet cistern inlet valve (blue cap as sold by Bunnings)
I decided to write this because most the information I read about this subject is not correct. In particular, the instruction pictures that come in the package are too small which makes them unreadable. The only understandable part is Made in China.
Installing a new Kinetic fill valve is not difficult if you follow these steps. The stem has two sections. The bottom slides inside the outer section. This allows you to set your fill height.
Before you start, you need to set the height of the stem. Free the sliding tubes by releasing the locking wedge (if there is one). They are often tight so use force carefully. Then hold the bottom stem and turn the top stem slightly ACW. This releases the locking lugs and allows the bottom tube to slide inside the top tube to give you the height (water level) you need.
Hold it inside the cistern and adjust the height until the top of the float is 25mm or more below the outlet overflow which is on the dump valve. If you want to conserve water, make this distance greater than 25mm. Then lock the two tubes by turning CW. You have now set your fill height. You do not set the height by adjusting the float mechanism. Most people attempt to do this.
Before installing it, check that the arm that shuts off the flow is set about mid travel or you will find that no water will enter the cistern when the water is turned on. There are two adjustments for this.
1/ The float can be raised or lowered slightly. To do this release the locking pin that sits on the float slide (on the centre stem).
2/ There is also a plastic screw rod that allows the float to go up or down. These are micro adjustments only and can be used to fine tune the water level.
Having set the height, and making sure that the on/off lever will work properly, mount the valve in the cistern. The triangle washer goes inside the cistern, then underneath it is a plastic washer and a plastic nut. Do not use a shifter to tighten the nut. Hand tighten only. The triangle washer is designed to seal the cistern with little pressure. Make sure the float is not impeded and mount it so that it is easy to access the locking pin if you ever should need.
Similarly, the flexible hose should only be very lightly tightened with a shifter. Always tighten the nut on the valve first or you stand a good chance of stripping the plastic threads on the valve inlet. If you strip them take the mechanism out and carefully run a female brass plumbing fitting on them to rre-cut the thread. Use a triangular file to help cut the thread properly. Do not use Teflon tape.
Once you have connected the chrome nut onto the valve, connect the other end to the isolating cock. Turn the water on and check for level and leaks.
The flexible hose must never be so short that it kinks. If it does kink, replace it. Do not take risks or one day you will potentially flood your house when it bursts while you are out. Replace the flexible hose every 2 years. They are cheap. Countless houses have been severely damaged by these hoses bursting. Especially on top floor dwellings. The same goes for the ones inside your vanity. Mark the label with a date and put it in your diary.
Hi @OVTP,
Thank you for sharing your experiences with the community.
Just a note for anyone looking to carry out this type of repair themselves: in many states and territories, work on a toilet inlet valve can be considered regulated plumbing work that requires a licensed plumber. Before attempting the repair, I'd recommend checking with your state or territory's plumbing authority to confirm what work you're legally permitted to carry out yourself. If you're unsure, the safest option would be to engage a licensed plumber to inspect and repair or replace the inlet valve.
