Hi - is anyone please able to help with how I change this broken handle to the new one? Thanks
Hi @fredd,
It looks like you've got a Whitco 5 Disc Push to Lock Chainwinder.
Having a look at the Installation Instructions, it says the following -
"Handle can be repositioned if required. Gently prise handle off with a screwdriver ensuring that winder body is protected by a cloth. Handle can then be pushed back in a different location"
This instruction appears to be about rotating the handle into a more accommodating position, but it would be the same process to replace the old, broken handle.
Give this a try and let me know how you go. I am happy to assist further if required.
Thank you - that got it off - but now I can’t push the new one on. It looks exactly the same (more so than the photo, I couldn’t get the angle exactly right) but it absolutely refuses to go on. I can push the old one back on no problem.
It definitely looks like it is the exact same.
Start by inspecting the hole to ensure there is no broken plastic or misaligned internal mechanisms blocking things.
I would then grab a rag to cover the handle, line everything up then tap it with a hammer.
It should go in with a bit more persuasion.
Let me know how you go.
Thank you! Sorry - took me a few days to get around to it, but the hammer did the trick 😊 much appreciated.
Glad to hear it @fredd.
Thank you for following up, and don't hesitate to reach out if you have any questions in the future.
