Building a small 19m2 pool cabana with exposed rafters. 6 degree pitch skillion colorbond roof.
I've come from Europe where a typical roof construction for this would be OSB screwed to the top of the rafters, a waterproof bitumen-based self adhesive roll product, 45x90 roof battens, metal roof sheets. (Only used in the North European summer so no insulation used). I get that the OSB is not needed for the roof construction - can just do metal on battens - but that wouldn't be pretty on the underside with exposed rafters. I can't really find much detail on this technique in Australia. I want to make sure i don't have condensation issues and I'd also like to include an insulation layer as it gets hot here in the summer. So i was thinking OBS, waterproof/membrane roll product, battens, Bradford Anticon 60mm (Installed vertical over battens as described in their preferred installation method), Colorbond. What membrane product do i use between the OBS and the Anticon. Or is there a better/alternative all-in-one product that will act as both the membrane and insulation? I'd prefer a combined foil reflect and batt product that the Anticon offers but could just go with a permeable membrane and foil product if it exists.
