Hello,
I am new to the diy building world and I'm sure I'm going to sound like the novice I am but we all must start somewhere.
I am building a 3 x 2m deck. I plan on digging 9 piers and attach 90 x 90mm posts using stirrups. I then plan to lay 190 x 45mm bearers in a 3m continuous span across the posts. I have three questions:
1. Does all this sound 'normal' so far? I have read a lot of people nailing two bearers together but I think that sounds like over kill?
2. I would rather not notch out my posts to support my beams, after all there is a lot of them and I am worried that I wont be able to keep them all level. Can I simply attach them using this? https://www.bunnings.com.au/pryda-30-x-0-8mm-x-30m-strap-brace_p1072800
3. At some point in the future I would like to extend the deck to the side so it becomes a 6 by 2m deck. I was hoping to place the bearer 45mm into the post, leaving a 45mm gap from the end. When I attempt the extension some time in the future I would then slide another bearer into the space and connect the two bearers using this https://www.bunnings.com.au/pryda-strap-nails-50-x-100mm_p2430030 . Does that seem safe?
Thanks for all your guidance,
(Also, if it matter, the deck will be 990mm above ground level and my piers are 700mm deep)
