Hi all,
I am about to undertake a DIY fence trellis that will not be a permanent fixture on our fence.
The distance between our fence and perimeter concrete is 0.395m. I am planning to use 90*90mm posts, cut to 1.98m in height.
I don't want to set the post directly into the ground; instead I would like to use anchors. Can you please advise me how deep the hole for the anchor should be, and what the required diameter would be also.
Thank you in advance.
