My neighbour and I are about to construct a 3m dividing fence between our duplexes. He plans on using Duratex exterior base sheet 3000 x 1200 x 7.5mm to clad his side (and we would likely use something similar).
Posts are 2.5mm galvanised steel that with 1000mm footing with 2000mm spacing.
He has created a design but I have checked the installation guides for duratex and hardieflex and they both say 600mm distances for vertical studs. If I could have some direction on what needs to be adjusted to support the fc sheets properly.
