how to glue clay pavers to a concrete driveway
Hello @Dyer2
Welcome to the Bunnings Workshop community. It's sensational to have you join us, and thanks for sharing your question about your driveway.
Paving over an existing concrete driveway is possible, but there are several important factors to consider before moving ahead. The first and most critical step is to assess the condition of the current surface. If the driveway is stable, with no major cracks, potholes, or structural issues, it may be suitable for paving. However, if the base is unstable, covering it with new material will only provide a temporary fix. In such cases, the new surface may crack, shift, or fail within a short time.
Drainage is another key consideration. Water trapped beneath the pavers can weaken the surface and reduce its lifespan. You should also pay attention to whether the driveway has an adequate slope or is built on an angle, as this affects how water drains away. Without proper slope, the pavers may loosen over time, especially under heavy weight, which can pose a safety hazard.
Although there are strong adhesives such as Selleys Liquid Nails Landscape Stone & Concrete Adhesive, Sika 1L High Strength Epoxy Repair Adhesive and Dunlop 2-Part Epoxy Builders Bond. I can't guarantee how they will perform when run over with a vehicle. It would be best to consult a professional to make sure the adhesive used can withstand the rigors of the driveway.
While it is possible to attempt this as a DIY project, hiring a professional is generally the better choice. A professional can properly assess the driveway, prepare the surface, and ensure correct drainage and compaction, which helps avoid costly repairs later on.
Let me call on our experienced members @Dave-1 and @AlanM52 for their recommendations.
Good Afternoon @Dyer2
Gluing pavers to a driveway is something id be hessitant to do. And it would be at the far end of attempting 🙂 Lots of issues come to mind, everything from drainage, weight, state of the existing slab and under the slab as well. Laying pavers over the concrete without mortar is where I would go but even then, if your driveway isnt totally flat or slopped totally flat trying to have sand and then pavers..... Runs into issues.
There are concrete stencils but I am never a huge fan of that. If you supply some photos of your driveway we may be able to come up with some workarounds.
Hi @Dyer2,
Let me also extend a very warm welcome to the Bunnings Workshop community.
Might I suggest you share some images of your driveway, and some detail about what you are trying to achieve with this project, then members might be in a better position to suggest alternative approaches.
All the best, we look forward to assisting with your driveway makeover and seeing it come to life.
