I am building a carport for my caravan and I would like the ground base to be some kind of gravel instead of a concrete slab. I will only be doing two concrete strips down the sides of the carport to anchor the posts into the ground. I will also use this gravel base on the driveway leading into the carport. Due to this, I anticipate that the gravel base will be a minimum of 18mL X 3mW.
1. How should I go about installing this gravel base so that it is sturdy and cost-effective?
2. Please let me know I use different materials/methods for the gravel driveway.
Thanks for your time!
