pipe black Rural poly pipe.+ rural "j" joint for tap riser. Leaks from the joint fitting (tried 3 different fittings)
Specifically water squirts from under the screw fitting along the pipe. side. and I have noticed that the male joiner, that fits inside the pipe to the Tap riser is not as tight as other joins are.
